andreas Ø
Model disalignment
Hi
On several occasions, and in different projects/files I experienced that the rendered model is not aligned with the physical model. It happens both when rendering in a viewport and directly on the layer.
It happens in all versions I have worked with since v. 14 (with renderworks) through to 2020.
In the attachment the blue line connects the same house...
Am I the only one with this issue?
Cheers Andreas
Edited by andreas Ø
Hi ASagatov
I did not see your reply till now. I have re attached the photo. Do you need anything else from me?
Kind regards Andreas
@andreas Ø I know I have seen this before, but I can't recall exactly the cause. If you go into a top/plan view of your model and do a Tools > Origin > Locate Internal Origin, does your model sit close to the blue crosshair? Do you see any objects extremely far away from the blue crosshair?
