The Object Info palette top/bottom bound options for a selected wall look similar to the Insertion Options settings. However, for a wall with components, the height or bounding changes made in the Object Info palette only affect the wall when its component bounds are set to Relative to Wall in the Wall Component Settings dialog box.
Request: gray/disable Top Offset and Bot Offset input boxesin the OIP unless the wall components are set Relative to Wall. Is there a use case where these inputs are needed? If not, having active inputs that do not affect the model is only a source for confusion.
E|FA
Per the help system:
0 answers to this question
