rDesign
Tutorial: Changes to Building Model Workflow In Vw2020
Reading through the Vw2020 Help File about New Features, I came across the following description under the section about ‘Architectural template and styles updates as a result of improved workflows’:
Quote
The workflow for modeling a building has changed; walls should now be drawn first, and then the slabs should be created on the same story. This process is repeated for each subsequent story. This results in changes to default templates; wall, slab, and roof styles; and other content files provided with Architect.
http://app-help.vectorworks.net/2020/eng/VW2020_Guide/Structure/Workflow_Model_setup_with_stories.htm#XREF_78064_Model_setup_with
Since this is a departure from the recommended workflow in previous Vw versions, I think a video tutorial explaining the changes to the recommended workflow is warranted. Thanks.
[EDIT: As a side note- the hand-drawn sketch of the Levels / Stories diagram on that Help page is pretty low-resolution quality and looks like it was taken by a hand-held camera. As an architectural floor construction sketch, it doesn’t make any sense: What is the part at the lower left? Where are the foundations for the part on the right?  Why are the two parts offset and separated? This sketch is more confusing than helpful. A better quality, more legible sketch would be welcome. In addition to a video tutorial. Thanks.]
Edited by rDesign
0 answers to this question
