Just Learning Posted June 5, 2005 Share Posted June 5, 2005 Trying to draw 3 connecting lines with each line a certain angle off the end point of last line drawn. Problem is when I draw the third line a certain angle from the second line, the angle of the third line is referenced off the first line drawn instead of the second line drawn. How can I zero out the angle degree in the menu bar so I can start at zero angle from the second line? Example: 1st line horizontal left to right, 2nd line 70 degree angle from end point of first line, 3rd line 87 degree angle off end point of second line. Quote Link to comment
jan15 Posted June 6, 2005 Share Posted June 6, 2005 JL, if you're talking about the "A" box in the Data Disply Bar, that has nothing to do with any lines or polyline segments drawn previously. It's degrees from the X axis, with zero degrees to the right and counterclockwise positive. Quote Link to comment
