ghunter Posted August 29, 2019 Share Posted August 29, 2019 There is a possible bug in the Heliodon tool. When you place a Heliodon in a designer layer, and change the render model to Open GL. If you change the time of day in the OIP, VW does not detect the change in the field and the screen is not re-rendered. If you then type in another time of day and exit the field, VW re-renders but using the PREVIOUS time of day you entered, while showing the new time of day in the OIP. This problem isn't obvious if you entered the same time of day. It appears as though it didn't re-render, then rendered correctly, but in fact it was using the first value you entered to render the current value. I found I can recreate this issue consistently. Thanks Quote Link to comment
