Luc Posted May 5, 2005 Share Posted May 5, 2005 Is it possible to use GPS co-ordinates in vectorworks to create a surveying module showing contours etc. Quote Link to comment
islandmon Posted May 5, 2005 Share Posted May 5, 2005 It's common place. As long as you have a grid point such as UTM ( Universal Transverse mercator Grid ) or Lambert Grid to start your Northing&Easting. Then set the document Orgin at that point ... where ever it may be in plan space ( not necessary to be on the page space ). Then reference every subsequent point from there. For GPS you need to work in mod60 not mod10 so > 52?36'22" = 52.6061 NOT 52.3622. That's all there is to it. You may also use a GPS Record Field to track the coordinates as a worksheet checksum against the Northing&Easting ( YX). Use DTM 3d Loci elevations at each of the grid points to compute the contours. Quote Link to comment
