Robin Malinowski Posted June 25, 2019 Share Posted June 25, 2019 Hello All, We're looking to create an issue sheet which comes straight from VWX (We are using a separate excel spreadsheet). This is just to save us time rather than having to manually update our excel sheet every time we issue a drawing, and when you have a large amount it takes time to update all the sheets and revision number ect... We have set up a worksheet containing all the relevant information which links correctly to the corresponding title block, however when it comes to the revision number we are having problems. The issue we're facing is that we would like the worksheet to automatically update the current revision number- however we cannot set the record field on the worksheet as 'current revision number', as all the previous revisions on the sheet will update with. Its almost like we need to the previous ones to freeze however we do not know how. See attached the layout of our worksheet issue sheet. Any suggestions? Many thanks. 1 Quote Link to comment
_James Posted June 30, 2022 Share Posted June 30, 2022 Did you ever solve this? Quote Link to comment
