Matthias Schwarz
Setting text size in Dimension object?
Hi all,
I like to modify the text size (e.g. enlarge 10x) of a dimension object in a PIO.
I tired both ovDimTextSizeInPoints and ovDimFontSize.  I can read these variables, but when I set them no effect?
At least GetObjectBounds() never gives a changed value, even after ResetObject().
Are these values ReadOnly or i missed something here.
TY + BR
 Matthias
If you look at the drawing Tree or try to ungroup your Dimension object (CTRL + U), you will find out that there are Lines Nodes and a Text Node :
You can then easily change the charSize of the Text Object with for example :
virtual void ISDK::SetTextSize(MCObjectHandle textBlock, Sint32 firstChar, Sint32 numChars, WorldCoord charSize);
Best,
