Stephan Moenninghoff 381 Posted January 2, 2019 I really like having the Valve but I needs it to be smarter. Could an option be added that portions of networks joining after the Valve are not affected? The Valve currently disables too much and could be used much more often if this was possible: In this case I want the dialog to pop up only if the valve before it has been enabled. Currently, the Valve kills my entire network downstram of it. Is that necessary? Could the Valve please also disable controls in the OIP? If a control comes after a Valve, this would be an elegant way of hiding it. Thank you! 3 Quote Share this post Link to post
Martin Lerch 0 Posted May 18, 2020 Hi Stephan, I just found your post while struggling with a similar problem. The valve node hasn't become smarter since, has it? Thanks Martin Quote Share this post Link to post
Stephan Moenninghoff 381 Posted May 18, 2020 5 minutes ago, Martin Lerch said: Hi Stephan, I just found your post while struggling with a similar problem. The valve node hasn't become smarter since, has it? Thanks Martin Not yet. I think I read somewhere that it is not as easy and straightforward to implement as one would imagine 🙂 1 Quote Share this post Link to post
