Change "Delete" key
If you go into the workspace editor you can customize the shortcut for the Clear command. You wouldn't be able to set it to just "E" (You can only use single keys for tool key shortcuts). You could set it to Command + "E" or something like that. (Command + "E" is the extrude key shortcut by default so you'd need to change that as well). Your only other option would be a third party application that lets you remap your keyboard.
