Koleen
Beams going through walls?
Hey, so I am a complete beginner at Vision, but through the help of the lovely forums and videos and instructions, I've started to get the hang of this.
One problem now though: my beams of light appear to be going through walls and I have no idea how to fix this!
I have already made sure my textures cast and receive shadows in my VWX file, as well as my lights.
Any ideas?
Edited by Cadesence
The "Enable Shadows" document preference is now disabled by default because (you'd never believe me when I say this) most people don't notice they are off and the performance increase is astounding.
Simply select ROOT and check the "Render Shadows" check box 😉
One last note (kind of tying in to what I said earlier), if you can run in realtime without shadows it will run WAYYYY faster. You can always toggle the shadows on and off in realtime mode to see what you need to see when you need to see it. I would recommend always enabling shadows for Rendered Stills and Rendered Movies.
Thank you for replying so quickly! I did check that box, but it still goes through?
Edited by Cadesence
I think I know what's going on. Go into your application settings (not document settings) and make sure Dynamic Shadows is set to "Objects".
Uhhh, sorry for having to ask this, but how does one get to application settings? ^^ ''
On OSX, you can click the Vision menu and then click Preferences (on PC it is Edit->Preferences). You can also use the default OSX keyboard shortcut that is used by all applications on OSX: Command+, (note: this keyboard shortcut does not exist on PC).
If you were unaware of this menu, make sure to check the help documentation, as well. There is a LOT of good stuff in there and you should try to understand all of these settings as they have direct impacts on performance and quality.
The settings that impact performance the most (and in order of importance):
  1. Resolution Quality
  2. Volumetric Quality
  3. Render Fixtures (with large number of lights)
  4. Shadow Quality
  5. Texture Quality
  6. Dynamic Shadows (should almost always be set to "Objects", which should be the default)
We tried to ship mostly sane defaults here, but feel free to try these settings out and store them off as presets.
Edited by bbudzon
Clarification
  4. Shadow Quality
  5. Texture Quality
OHHH. HA! I was aware of this menu, for me, it's Vision Preferences, not Application Settings (though they may mean the same thing, idk)
And I will make sure to help myself to all the help documentation as well!
By the way, it worked!
Thank you so much!
Glad to help! You are right about the menu not being called Application Settings but we will refer to the settings in that menu as Application Settings because they are stored in the Application and NOT in the Document. Similarly, Document Preferences (such as Render Shadows) ARE Document Preferecences and therefore will be stored in the v3s. When you email Vision files to others, the Document Preferences will carry along but Application Settings will not as they are set on a per user basis inside the Application itself. (This is similar to how VW handles Application/User Settings vs Document Preferences.)
