SKB Posted November 26, 2004 Share Posted November 26, 2004 I am trying to diagnose why my file does not open in ACAD when exported out as a 2002 dwg drawing. The issue appears to be in the viewport layer. The file starts to open and then hangs. The file contains multiple viewports at different scales. When I cut and paste the model layers into a new drawing the model layers export out and open fine. If I try to make new view ports the same issue occurs. Quote Link to comment
Hugo Posted November 27, 2004 Share Posted November 27, 2004 I have had a similar problem like the one you describe. My exported DWG files seemed to hang Autocad in a PC. But I discovered that if I pressed the ESC key in the PC, when it seemed to be hang, the file finally opened. I'm sure this is not the correct way it should work, I think VW outputs some complex data Autocad doesn't know how to handle very well. Hope it helps. Quote Link to comment
SKB Posted November 29, 2004 Author Share Posted November 29, 2004 Thanks for your comments, I will experiment with this a bit. It appears that the complex data you mention may be related to parametric data from 3d objects although I have not been able to confirm this. I have exported regular 2d drawings with multiple viewports and there is no issue. I suspect there must be an additional step required to strip away the parametric data before exporting? Any help from Tech support would be greatly appreciated. Quote Link to comment
