jshowers Posted September 14, 2018 Share Posted September 14, 2018 (edited) I am working on some rigging calcs for a gig that is going to be in a tent. 2019 Test File attached, as well as the original file (Zoo Gala). I have a few observations/questions: 1. Using a Pipe as a Hanging Position and then duplicating it is giving me an ID already in use BW error, but I see nowhere to edit the ID for each Pipe separately? 2. I am getting a Virtual FEM error for the end of the truss where everything appears kosher to me, i don't see how one leg of the bridle is getting lifted (which is how I read this error from the online help?) 3. I copied this entire system from our actual working file and pasted it into a new document which is the one attached here. When I did this I also rotated the entire system so it was landscape orientation just to make complete system viewing easier. Everything appeared fine until I ran the BW Calculation again and this caused my house rigging points to be duplicated for some reason? I left them this way in the file instead of deleting them. 4. More strangeness, general VW 2019 related. When I was in my working file, ASP Gala, I use the selection tool to select all the elements on the left most side of the drawing ONLY. I opened a new document and pasted in my selection. However, instead of pasting just my selection from the Gala drawing, it pasted ALL the elements existing in my Gala drawing into the new document. Braceworks 2019 Bridle Testing.vwx ASP Gala v2019.vwx Edited September 14, 2018 by jshowers Quote Link to comment
SCParker Posted September 14, 2018 Share Posted September 14, 2018 For #1, use the "Reset Braceworks IDs" under the Braceworks pulldown menu. I've not opened your file yet as I'm in the middle of other things. I'll take a look and post if someone else doesn't beat me to it. Quote Link to comment
jshowers Posted September 14, 2018 Author Share Posted September 14, 2018 (edited) Ok thanks. I have also noticed that my Alpha Profiles that are attached to the hanging position pipes become unattached at random after calculation... I have used the Reset BW ID menu command and it does fix this problem, temporarily. I have to reuse it every time I calculate or the ID error keeps showing up...not really a problem but a tad irritating. Edited September 14, 2018 by jshowers Quote Link to comment
