jmartinarch Posted November 10, 2004 Share Posted November 10, 2004 Is it possible to snap to objects that are not in current class? I imported a .dwg file, set a new class, tried to trace a portion of the imported drawing, but could not snap to endpoints. So I changed class, traced, then edited. Is there an easier way? Quote Link to comment
jan15 Posted November 10, 2004 Share Posted November 10, 2004 When the Class Option is "Show Others" or "Grey Others" you can't snap to objects in other classes. When it's "Show/Snap Others" or "Show/Snap/Modify Others" you can. The same is true of layers. And with layers, if the object is on a layer at a different scale, you can't snap to it no matter what the Layer Option is. To change Class or Layer Options, pull down the Organize menu. Quote Link to comment
