Kaare Baekgaard Posted October 25, 2004 Share Posted October 25, 2004 Resizing imported images - using the corner handles - works different than resizing other 2D VW shapes: I cannot enter a new object width/heigth by tapping into the data display bar (unless I place the image with its bottom-left corner in the exact center of the drawing). This is a minor nuisance, but still you should fix it for the next version. Quote Link to comment
jan15 Posted October 25, 2004 Share Posted October 25, 2004 You can use the Scale Objects command or the Object Info Palette to get the image to the dimensions you want. Or, using the data bar, you can draw a rectangle which has the size and shape you want the image to have, and then drag-stretch the image to the corners of that rectangle. Quote Link to comment
