Wall overall thickness setting should become Target thickness when the wall has components. Instead of current behaviour.
Firstly it would help to set an expected overall then see how the build up differs.
This would let us record and maintain a design assumption or a site measured thickness in the wall type then see if the component build-up was matching or might need tweaking.
System should still report stats in the text beside the box without making the box inactive. ie "265mm Determined by Components (5mm below target)"
Matt Overton
0 answers to this question
