td4stage Posted July 29, 2004 Share Posted July 29, 2004 I have a couple window and door 3d pios in my drawing. When I go to customize the component parts of the pio, I go to the Object Info Pallette and class settings. Under each item there is none then style-1 thru style-15. I change these and nothing seems to happen. Is there a place in the manual that denotes what each style is? TIA, Quote Link to comment
Guest Posted July 29, 2004 Share Posted July 29, 2004 You have to specify the attributes for each one of the styles through the classes dialog box. By selecting one of the styles, a coordinating class is created. You have the choice to set the attributes for that class. The default is solid white fill and black pen. Quote Link to comment
