Reference Markers
Would anyone be able to tell me how to turn off the solid fill behind the text in reference markers. When I use these objects with "config 1" I am unable to have very many letters or numbers in either category before a solid fill begins to appear outside of the markers circle. If the solid fill is turned off the fill behind both the text and the circle is removed. I would like to be able to still have a solid fill be hind the circle but not behind the text.
I am using VW V11
Any help would be appreciated
Thanks Denny
[ 07-27-2004, 09:11 PM: Message edited by: superden ]
Katie you are a real trooper working after hours, heck working after midnight! Thank you for all your hard work.
I tried your suggestion and did not get the desired result. It works on general text made with the text tool, but has no effect on the Drawing Object Label.
You are right. There isn't a way to do that without ungrouping it.
I'll add this to the wish list.
I couldn't sleep last night, so I got on the internet - and thought I'd stop in here for a minute. =)
