I’m having a little difficulty with VW architect that I thought you might have a quick answer to. I am unable to create site models. I have tried several different methods including the grid entry method and the 2d polygons to 3d contours. This part works fine and the locus points are created but when I go to the AEC menu and select site model things don’t go so well. The site model box comes up and I select the layer options and the properties that I want. All goes well until I hit OK. The first thing that happens is a script error comes up telling me that a vectorscript error has occurred and to refer to the error output for further info. The error output says - Error: _587 _137 - Menu cannot be found. Edit Plant Catalog
At first I thought that it may have been a problem with my set up so I uninstalled VW and then reinstalled. Before I reinstalled VW Architect add on CD I created a site model using the VW standard set up, which worked fine, no problems at all. Then I installed VW Architect and the original problem occurred again.
Any help you could give would be much appreciated
Thanks
