Stuart Gray Posted June 25, 2004 Share Posted June 25, 2004 When we export VW files to some of our Consultants using AutoCAD they are reporting that the walls (drawn using ones set up with the wall library in Architect), that had hatches to show the inner and outer leafs of the cavity walls are showing up with a black solid fill. Are we doing something wrong with our export or if this is just a conversion problem is there a quick way yo turn oof all of the fills to the cavities so that the walls just show up as lines? Many thanks in advance Stuart Gray FAW Architects Northampton, England Quote Link to comment
Guest Posted June 25, 2004 Share Posted June 25, 2004 When you export from VectorWorks, are you checking to export 2d hatches? There is a checkmark box with the option to not export hatches. Quote Link to comment
Stuart Gray Posted June 26, 2004 Author Share Posted June 26, 2004 Thanks Katie, I'll check that when I get back into the office frst thing Monday morning..... I'm fairly sure that it was checked, so hopefully problem solved! Thanks for the response, especially on a Friday evening!! Quote Link to comment
