Jord Visser
Got stuck on a compiling error in PIO
Hi all,
I'm made a rough PIO in vectorscript yesterday, this morning I added a procedure and it keeps getting stuck on a compiling error.
I rewrote the function several times now, checked all the IF-ELSE's, WHILE's and BEGIN's and I keep falling back to this error.
The MakeGrayObject Procedure is the one I added this morning
The error is:
Line #42: PROCEDURE LTSymbol;
{ Error: Extra text at end of script; missing BEGIN statement? }
{ Error: Identifier not declared. }
I attached the pascal .txt file and the .vso, both only tested in VW2018.
Can someone help me with this?
With kind regards,
Jord Visser
ltsymbol.txt
[LT] Advanced symbol.vso
24 minutes ago, JBenghiat said:
You've defined LTSymbol as your main procedure, so any other procedures need to be inside that scope, i.e. place sub-procedures after the main procedure's TYPE, CONST, and VAR sections.  Refer to the VS language guide for information on scope: http://developer.vectorworks.net/images/7/72/VectorScriptGuide.pdf
Thanks for the quick reply! works as a charm.
Makes a lot of sense now, quickly read trough the mentioned document a couple of times before.. I think it's time to read it thoroughly.
