td4stage Posted October 3, 2017 Share Posted October 3, 2017 Running VWSL 2018 on a Mac running High Sierra. Working on a light plot and beginning to insert focus points. They begin at letter "T" and go from there...not A. I've made all of my layers visible and there are no stray focus points. Is there something else I need to reset? This has never happened to me before! Time Passes...... Welp. I completely cleaned out the drawing, redrew most everything and copied in the scenery (after changing fills to "non" so as to look for anything hidden). STILL going A, S, T, U.... Seriously going to scream soon! Pat Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted October 3, 2017 Vectorworks, Inc Employee Share Posted October 3, 2017 If you go to Tools > Custom Selection, execute a search immediately, and then set the parameters to Type - Is - Focus Point, does it report via the counter near the bottom of that box that there are other Focus Point objects in the document? Does the same erroneous lettering happen in a new blank file for you as well, or only this current one? Quote Link to comment
td4stage Posted October 3, 2017 Author Share Posted October 3, 2017 So this is what I get...6. And that is how many FPs I *think* I have. Just tried it with a pure fresh drawing and it did you A B C... For the life of me, I can't find these extra FPs... Thanks Jim! Quote Link to comment
td4stage Posted October 4, 2017 Author Share Posted October 4, 2017 I'm just throwing things at the wall to see if anything sticks...I did an export to LW6 and Focus points / Purpose B-R were nowhere to be found. Same result when running a channel or instrument report directly in VWSL. Pat Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted October 4, 2017 Vectorworks, Inc Employee Share Posted October 4, 2017 If you can message me with that file I can take a look. Quote Link to comment
