cmuraglia Posted February 24, 2004 Share Posted February 24, 2004 I remember there being a folder with "Image Props Hi-Resolution & "Image Props Low Resolution" I cannot find these folders after installing 10.5.1. I have gone into all the program folders and do not see them? Should I reinstall everything? Any help is greatly appreciated. Chris Muraglia Quote Link to comment
Guest Posted February 24, 2004 Share Posted February 24, 2004 Look in the textures folder. The two High and Low image props are actually VW files in the Textures folder. Quote Link to comment
Guest Posted February 24, 2004 Share Posted February 24, 2004 Chris, There should be 2 files in the textures folder called Props Hi-Res.mcd and Props Lo-Res.mcd. I think these are the files you are looking for. Quote Link to comment
cmuraglia Posted February 24, 2004 Author Share Posted February 24, 2004 Thanks for the replys. These folders are simply not in the folders. I must say I am baffled as I used to use them, and I did not delete anything. Is there a way to install just these folders, without going through the whole installation procedure starting with 10.0? Thanks Chris Muraglia Quote Link to comment
Guest Posted February 24, 2004 Share Posted February 24, 2004 There are no folders for hi and low res proprs. They are VW files, which are the library files. In the resource browser, the files in the library are all VW files. To add the high and low res props to the Library files in the RB within VW, go to Add New Favorite in the RB (click on the arrow at the top next to Resources) Migrate to the VW 10 folder. Within the VW 10 folder, open the textures folder. You should see the HI and Low res image prop VW files here. Select them and click on Add. Quote Link to comment
