L+K Posted January 22, 2004 Share Posted January 22, 2004 Have you ever heard of Structural Shapes magically converting into "Polylines" instead of their original shape? All of the data about the I-beam has been lost, but it still looks like an I-beam shape. If so, why did it happen & how can you fix it? Quote Link to comment
Guest Posted January 22, 2004 Share Posted January 22, 2004 Did you ungroup it? If you ungroup it, it becomes a polyline and loses it's plug-in data. You are prompted each time you ungroup a plugin object. Quote Link to comment
L+K Posted January 22, 2004 Author Share Posted January 22, 2004 No, I couldn't ungroup it - I tried, to see if that's what happened, but it's not! The file was brought into the latest version of VW from a MAC to a PC, could something have happened there? On the MAC, they still have there structural info & I put them in a "Structural Grid" Class- however, if I say ACTIVE ONLY for that class, they disappear & I can't seem to fine their true identity. Quote Link to comment
Guest Posted January 22, 2004 Share Posted January 22, 2004 make the structural class and the none class as the only visible ones. Then select the object. See if it says "polyline" in the OIP or if it says I beam or whatever the plugin in. The breakup wouldn't happen in a conversion process or cross platform. If it's reading as a Polyline in the OIP then the object was ungrouped. If you still can't ungroup the object, then it's probably a polyline, implying the plugin had to be ungrouped at one point in time. Quote Link to comment
