Stefan Posted January 16, 2004 Share Posted January 16, 2004 Hey, Got a problem here. Im copying a drawing from one file to another, and when i delete that drawing in the new file, it only deletes the objects and not the dimensions. Now when i do this, the dimensions get 'stuck' you could say. I can't select the dimensions at all, both by selecting with mouse and with command-a. I know for a fact that the dimensions are on the layer that im working on tho, because when i set layer options to view active only, on every other layer the dimensions disappear. Hope this makes sense and I hope someone can help me. OSX 10.2.8 Vectorworks 10.1.2 256 M Ram Quote Link to comment
Guest Posted January 16, 2004 Share Posted January 16, 2004 GO to Organize>Class Options. Select "Show, Snap, Modify Others". THat should allow you to select the dimensions. If you only want to select the objects on a specific layer, leave the class options set to the above and Layer Options set to "Active Only". Quote Link to comment
Stefan Posted January 19, 2004 Author Share Posted January 19, 2004 Well, thank you Katie. I was going crazy for a sec there. Your always a big help in here Quote Link to comment
