DPI Posted December 10, 2003 Share Posted December 10, 2003 IN V10.1 IF I WANTED TO USE THE LINEAR ARRAY WITH DEFAULT NUMBER 1 I COULD JUST TAB THRU THE BOX UNTIL I GOT TO THE MANUAL OFFSET WINDOWS. NOW IN V10.5 IF I TRY TO TAB THRU THE DIFFERENT ARRAYS TO GET TO THE OFFET WINDOWS IT STOPS ON CIRCULAR ARRAY AND AUTOMATICALLY CHECKS THE ROTATE BOX. WHAT'S THE DEAL? Quote Link to comment
P Retondo Posted December 10, 2003 Share Posted December 10, 2003 DPI, I believe this has been noted by others and tech support as a bug. If you search the site, you will probably find the discussion. Quote Link to comment
Guest Posted December 12, 2003 Share Posted December 12, 2003 It is a bug and the engineers are currently working on the problem. You will have to click with the mouse in the dialog box to get what you want to do. Quote Link to comment
