DomC
Marionette PIO for layer numbering
This Marionette Object Shows its layer name (last word) and the layer stacking order as a label. I often create documentation inside Vectorworks and do not want to use other applications for that. All we need is Vectorworks!
Contains some custom nodes:
1. "GetAllLayer" A List of Design Layers and a List of Sheet Layers
2. "Backward" A node to send an object in background (did not fount a native node for that ..?)
3. "GetLastWord" split the last word from a string
4. "GetObject" Wrapper to grab a Text Object with a Text Style and to transport this Textstil by copy/paste the script
Nothing spectacular but could be handy and really helps saving time compared to manually texting or stamping a counter on every layer. Also with the "GetLastWord" node, the layer can contain the chapter in his name.
page_numbering.vwx
Hi DomC
Thank you for the file!
I am currently trying to extract the first character from a string to be used to make a text object. I thought that I could alter your "GetLastWord" to do this.
Would you be able to help me out on this?
Thanks
In python, strings are treated as list objects.
# So take for the example the string below
some_string = "four"
# in python strings can be thought of as lists
# some_string = ['f','o','u','r']
# so to get the first character just use list slicing, calling the index of the character you are after in the string:
some_string[0] # will be equal to 'f'
# second string:
some_string[1] # will be equal to 'o'
# and so on..
# and to get the last character, use negative indices
some_string[-1] # last character = 'r'
hth,
Tui
Edited by twk
