carch Posted November 3, 2003 Share Posted November 3, 2003 Hello, i'm trying to modify my 00_Arch_Sheets file. which i can do, but it only effects Arch B sheet size. How do i get it work for all Arch sheet sizes. More about the the file: when i open the file, 00_Arch_Sheet i see two layers with two sheets Layers Catalog Page layer 1 Sheets Sel Nonplot Unzero Arch B horizontal and Arch A vertical. Is this correct? Help Thanks Chris Quote Link to comment
Guest Posted November 3, 2003 Share Posted November 3, 2003 After the file is open, select OO Arch sheets from the OPEN FILE portion of the Resource Browser and select the title block size you wish to edit. After changes are made, save the file and close it. The changes in the title block size will only take affect on new documents, not existing docs. Quote Link to comment
