DIZNEY Posted October 10, 2003 Share Posted October 10, 2003 Greetings: I am using Version 10.1.2 and am frustrated at the over sensitive nature of the buttons in the various palettes- If I click on the line type/weight button in the attributes palette often it will flash very quickly switch the line to a dashed line and then close all in under a second- of course if I slow down and wait for it to open it works - but I was hoping to be able to do something aside from having to slow down my work- On a similar note, I can find myself having to click other buttons multiple times like the 2d selection tool for example- when I am working quickly and moving the mouse back and forth from the 2-D palette, I can see the program recognizes that I have selected that tool when I click on the button because it starts to press down the button- but then it doesn't actually push it all the way in and select that tool- again this is when I am working fast- if I slow down it works better- so am I just lost on this one- or is there a way for vectorworks to keep up with me and not interupt "the flow"? Quote Link to comment
Bart Rammeloo Posted October 10, 2003 Share Posted October 10, 2003 using shortcuts would be one option. The arrow selector can be activated by using the X-key. Using the right mouse button on windows sometimes helps as well. Getting a faster system is of course also a solution Cheers, BaRa Quote Link to comment
