sutherland craig partnersh Posted October 7, 2003 Share Posted October 7, 2003 At present when you are dimensioning in vectorworks it automatically goes onto the class layer dimension by default. Is there a way to change this so it goes onto a new class created by the user ?, ie dimension-ext. walls. We currently have to dimension on the dimension layer and then change/move it to the class we require which is obviously a touch long winded. Your help would be appreciated. Quote Link to comment
Guest Posted October 7, 2003 Share Posted October 7, 2003 There is not a way to change this setting. You can rename the dimension class, but it sounds like you need multiple classes for various types of dimensions. Quote Link to comment
Kevin Posted October 7, 2003 Share Posted October 7, 2003 I run into the same issue. I dimension the Mod-Floor Plan. Then I layer link this plan to my site plan. I need to dimension the site plan but I don't want the dimensions of the Mod-Floor Plan to show. I only want a few dimensions on the site plan showing distance of building to property lines. This forces me to have the dimensions of the Mod plan as Dimension-1 and the dimensions on the Site plan as Dimension-2. Is this the way it is supposed to work or is there a better way? Quote Link to comment
Ray Libby Posted October 8, 2003 Share Posted October 8, 2003 Yes, in my opinion it is the way it's supposed to work. This is parallel to the discussions of groups defaulting to the none class and I agree with the way VW handles both. To answer your question, I think a better way would be to rename your dimension classes to ModDim and SiteDim, only to make them more recognizable (not sure if that is what you were after). I never change the name of the none class or dimension class. I think it does take a certain amount of discipline for this system, but like anything else once you get the flow it comes easy. Quote Link to comment
