Ken White Posted October 6, 2003 Share Posted October 6, 2003 As near as I can tell the Offset tool no longer behaves correctly with multiple objects. In previous versions I could create a buch of squares which butt up against each other. Let's say they form a 4x3 grid of blocks. Select all of the squares. Get the offset tool (by point mode). Set an offset distance, and make sure multiple objects is checked. In the past I could click inside the front most object, and all of the boxes would have a square offset to the inside. However, now when I click on any square the same thing happens. The square that I click inside has a box offset inside, all others have a square offset to the outside. Oops! This is at least the way it is working right now on a Mac under OSX. Can others replicate this problem, and can it be added to the bug fix list. Thanks. Ken Quote Link to comment
kiwi Posted October 6, 2003 Share Posted October 6, 2003 Oops! on the outside twoo. I never use the tool with the multiple objects selected on previous versions, but on 10.5 under OXS 10.2.8, all less the clicked of a selection of objects will only ofset on the outside. Quote Link to comment
Guest Posted October 6, 2003 Share Posted October 6, 2003 It looks like this is a problem in all VW 10 versions. (all the ones I tried). VW 9.52/3 work fine. I'll bug list this. Quote Link to comment
