zero Posted September 30, 2003 Share Posted September 30, 2003 When creating a new wall type, how do you know which side will be used as the "outside" when inserting door and window objects. ie, which side will the window external sill line be closet to when you ctrl drag a window from one wall into another wall? Thanks in advance Quote Link to comment
Vectorworks, Inc Employee Andrew Bell@NV Posted September 30, 2003 Vectorworks, Inc Employee Share Posted September 30, 2003 quote: Originally posted by zero: When creating a new wall type, how do you know which side will be used as the "outside" when inserting door and window objects. ie, which side will the window external sill line be closest to when you ctrl drag a window from one wall into another wall? When you're in plan view and select a wall, a little triangle will show up that shows the wall's orientation. The "outside" is consistently one side relative to that direction, I forget which (I think on the left, but one test with a window should tell you for sure.) If you use wall cavities (hatches that show the wall composition), that can be a helpful indication that your walls are oriented properly. Quote Link to comment
