Oachl Kini Posted November 18, 2016 Share Posted November 18, 2016 (edited) Hi! I'm trying to build an easy house in my script, but I can't get the joinWalls-command to work. Here's my code: vs.Wall(0,0,0,10) w1=vs.LNewObj() ww=vs.WallWidth(w1) vs.HMove(w1,ww/2,0) vs.Wall(0,10,10,10) w2=vs.LNewObj() vs.HMove(w2,0,-ww/2) vs.JoinWalls(w1,w2,(ww/2,10-ww/2),(ww/2,10-ww/2),2,0,1) First I had to move the walls so the edges fit. Now I can join the walls using Alt+W, but I just can't get the function to do it....Any help? Ok.. now it works.. Just used vs.JoinWalls(w1,w2,(ww/2,3),(3,10-ww/2),2,0,1) Thought I tried that one before.... Now my problem is that I can't join the last wall to the first... Edited November 18, 2016 by Oachl Kini Quote Link to comment
DomC Posted November 18, 2016 Share Posted November 18, 2016 (edited) Hi Hm, I think your main problem is, you overwrite the handle (w1 = vs.LNewObj()) of your first wall. So you don't have it anymore, to join your last wall. You somehow have to copy the handle of the first Wall. I made a Script with a more flexible (which would be more flexible with more walls) script, that would work for me. It first loops the input points and draw the walls. Simultaneously it put the walls and points in another list-variable (named walls) with all values needed to joint them anytime later (point and handle). Second it loops through that wall-list-values and do the join job. Always the last point from actual(i) wall with first point next(i+1) second wall, and so on. i is the "loop counter". Loops and list variables are extremly powerfull instruments for scripts. Maybe it looks more complicated in your eyes like your original script. wv = [[0,0],[0,10],[10,10],[10,0],[0,0]] walls=[] for i in range(len(wv)-1): p1=wv[i][0],wv[i][1];p2=wv[i+1][0],wv[i+1][1] vs.Wall(p1,p2) w=vs.LNewObj() walls.append([w,p1,p2]) if i == len(wv)-2: #append first wall again to have a join object for the last wall walls.append([walls[0][0],walls[0][1],walls[0][2]]) vs.AlrtDialog(str(walls)) #Debug for errors, delete if it works for i in range(len(walls)-1): w1 = walls[i][0] w2 = walls[i+1][0] p1 = walls[i][2] #second point from actual (i) wall p2 = walls[i+1][1] # fist point from next (i+1) wall vs.JoinWalls(w1,w2,p1,p2,2,0,1) Edited November 18, 2016 by DomC 1 Quote Link to comment
Oachl Kini Posted November 21, 2016 Author Share Posted November 21, 2016 Thanks, Dom! Looks nice and a lot better than my code, though mine wasn't supposed to - it was just a first test. :-) So, it definitely works, but now my code also works just fine. It didn't on friday... Sometimes I sooo love programming................... Quote Link to comment
DomC Posted November 21, 2016 Share Posted November 21, 2016 Thanks for feedback Quote you overwrite the handle (w1 = vs.LNewObj()) of your first wall That comment certainly was wrong ..., sorry :-) Quote Link to comment
