Josh NZ Posted November 10, 2016 Share Posted November 10, 2016 I have two viewports both had the same render settings (bottom image). I adjusted the scale of the upper image and now looks as shown. Have tried to use the eyedropper tool and have ticked the options shown below, this has no effect on the upper VP. Any ideas? Quote Link to comment
Josh NZ Posted November 10, 2016 Author Share Posted November 10, 2016 Also if I change the Foreground render from hidden line to none the whole VP shows as blank. Have set Background render to Final Quality Renderworks and still shows as blank. Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted November 11, 2016 Vectorworks, Inc Employee Share Posted November 11, 2016 Even after clicking "Update" in the object info palette? Quote Link to comment
Josh NZ Posted November 13, 2016 Author Share Posted November 13, 2016 Hi Jim, yes the above still showed after clicking update. On the second image I ticked then unticked "display planer objects", this made the same change to the appearance. I then changed to openGL and could see the image again. Quote Link to comment
