ionw Posted September 22, 2003 Share Posted September 22, 2003 In a new document, I pick the line tool, (using click-click) click to start the line hit Tab enter in say delta x = 2" delta y = 0" tap enter after each entry I get the expected guidelines two inches to the right on the same horizontal plane. If I pick the Arc tool, (any mode) click to start the arc, hit tab and enter in say delta x = 2" delta y = 0" and the guidelines jump to (0", 2") that is 2" horizontal of the origin. If I don't use keyboard entry the tool behaves normally. I haven't spent a lot of time drafting in 10.5 so I don't know if this is an isolated tool. I will add to this topic if other tools crop up. Prior to this problem came to light, I had the door and window corruption after updating to 10.5, so I deleted everything, application folder, plist, preferences, workspaces, restarted Safe Boot (Mac OS X.2.6), repaired permissions, restarted off of a Diskwarrior 3.0.x CD repaired all damage, restarted, made sure there were no applications running & reinstalled from the 10.1.2 CD from NNA, and applied the 10.5 updater. I have tried using my custom workspace, and tried using the supplied Architect Workspace. Quote Link to comment
ionw Posted September 22, 2003 Author Share Posted September 22, 2003 I just realized that the data display bar, that displays coordinates until a tool is active, at which point it switches from coordinate to delta "mode" works properly for line, but for arc it does not switch to delta "mode." Quote Link to comment
ionw Posted September 23, 2003 Author Share Posted September 23, 2003 Is this a reproduceable bug for anyone else? I've done it on 3 machines now. I use Keyboard entry often, and I do use an arc or two.... thanks Quote Link to comment
