har Posted September 12, 2016 Share Posted September 12, 2016 Hi all, I'm quite sure my question has already been answered as Google turned up some results - But redirecting to the new forum domain doesn't work, which is a bit frustating... Basically, I've written a Node that will create a few symbol instances and other objects based on Pop-Up OIPControl input. So far, so good. However, I need this node to be an Object Node for a proper workflow. Then again, the OIP Pop-Ups don't carry through to the Object Node's OIP which makes the whole thing nonsensical. - Do I have any possibilites to "expose" my OIPControl Pop-Ups to the "parent" Wrapper / Object Node? Thanks all for the input! Quote Link to comment
AlanW Posted September 12, 2016 Share Posted September 12, 2016 Hi, If you look into this network you can see where the popus are used and how they appear in the OIP. HTH Fence_Sq_or_Circ_KM_AW_001.vwx Quote Link to comment
har Posted September 12, 2016 Author Share Posted September 12, 2016 OF COURSE - I should've just given my Script a name to make the Popup accessible from "outside". Sorry, it's been a few weeks.... Quote Link to comment
AlanW Posted September 12, 2016 Share Posted September 12, 2016 Yes, anything you name will appear in the OIP. The actual order of the items in the OIP is uncontrollable so far unless someone has sorted it now. Quote Link to comment
