Matt Basher Posted May 13, 2016 Share Posted May 13, 2016 I am trying to use the Create Report function to count the symbols in my file. It comes back as counting 1 for every symbol. This is obviously not working correctly, or I am not doing it correctly. Also, is it count per layer, or for the entire file? Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted May 13, 2016 Vectorworks, Inc Employee Share Posted May 13, 2016 This should cover how to modify that: http://kbase.vectorworks.net/questions/518/Summarize+the+Total+Number+of+Uniqure+Objects+in+a+Schedule+Without+Redundancy Quote Link to comment
Matt Basher Posted May 13, 2016 Author Share Posted May 13, 2016 That didn't help, but thank you for the response. I am trying to show the number of brackets (etc) that are redundant. One would think that this part of the link would help do that, but it didn't work. Here's how to show the number of unique object types: Highlight column A and click the Worksheet menu icon (the triangle to the left of the Descending Sort icon). From the drop-down menu which displays, select Insert > Column; a new column A is inserted. In the cell at the intersection of column A and the header row, enter a value of 1. The individual totals of unique objects are summarized in column A. Any other advise? BTW - My symbols don't have records, they re just parts of a larger structure. Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted May 13, 2016 Vectorworks, Inc Employee Share Posted May 13, 2016 Well the count next to each symbol database row will always be 1, but there should be a total count in the database header row or in a summary row, if you can post your file or email it to tech@vectorworks.net I can take a look. This should be doable with or without records attached to the symbol as long as the Symbol Names are correct. Quote Link to comment
RickR Posted May 14, 2016 Share Posted May 14, 2016 Down in the shared resources here I posted some basic worksheets. One is a simple count by symbol name. https://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=211698#Post211698 Quote Link to comment
