Developer Wiki and Function Reference Links Read more... ×
Sign in to follow this
AFDesign
Progress Dialog bug?
Hi,
I have the same problem reported in this post using "progress dialog" function on a plugin I wrote. You can quickly reproduce the problem in this way:
1) create a new script and paste "example 1" from here
2) run the script: if you click cancel button it works correctly; if you push the ESC button all stops but the dialog remains opened and, even if you close its window, vectorworks menus are locked and grayed out (impossible to quit)
Tested with Vectorworks 2016 SP1 on OSX 10.10.5
Any workaround to solve this adding some code to the example??
Thanks
Share this post
Link to post
Hello,
It seems this is a bug in the software.
Unfortunately, I cannot find a workaround.
Thank you for reporting it. I've added a bug issue request and hopefully it will be fixed soon.
Regards,
Vlado
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
