Guest Posted March 21, 2003 Share Posted March 21, 2003 Cherie, Did you get it when you acessed the Task Manager menu or when you were selecting a task or when you clicked on OK? What exact version of VW and Operating System are you using? Quote Link to comment
cherie Posted March 21, 2003 Author Share Posted March 21, 2003 katie, i got the message when i accessed task manager menu. the scroll downs were blank and below that there were a lot of numbers jumbled together. i am using vw 10.1 (with architect) and mac osx.2.4. Quote Link to comment
cherie Posted March 21, 2003 Author Share Posted March 21, 2003 katie, i had also better back up a bit. the original file crashed when quitting after printing. when reopened, i got this message "file is damaged. it will open with as much data as possible". i clicked ok and then got this message "39 end of file reached during read. attempt to read file -FSREAD." the file then opens with the word "recover" in file name. task manager acts the same in this file as in the new copy of the file. also another problem occurred after this problem, my email program, outlook express, will not open but i get a similar message, "an error occurred while launching. end of file was reached." Quote Link to comment
cherie Posted March 22, 2003 Author Share Posted March 22, 2003 just got this error message: error_1815_1770-index outside array limits. i got this message after opening a file and going to task manager (it was just full of numbers). this file had previously crashed when sending to print. anyway to fix this or do i need to copy it into a new file? Quote Link to comment
Guest Posted March 24, 2003 Share Posted March 24, 2003 Cherie, It sounds as though you are having a system problem with hardware perhaps. I suggest running First Aid in the Disk Check utility - Go to hard drive>Applications>Utilities>Disk Utility. Click on the First Aid tab. Run the verify and fix disk permissions as well as disk check. Quote Link to comment
cherie Posted March 25, 2003 Author Share Posted March 25, 2003 katie, i ran the disk utility on friday and along with one other fix within my email program, that is working. but, the vectorworks file is still messed up and i also noticed element are now not in the layer or class they were created in. i'm not too far along on this project to start over but my fear is that this will happen in the future when the project is nearing completion. Quote Link to comment
