TiTaNiuM sAMuRai
OSX.2.4 Right-click craps out in VW (953) only
Disk permissions have been fixed, Logitech's latest driver has been installed.
A fellow user has reported the following.
The right-click functionality of the mouse becomes disabled in VW only, after several usages. It still works in Finder and other applications, and is restored after some manual cmd-C and cmd-V commands, but restored for only 4 or 5 usages before it craps out again.
thoughts?
Does restarting the computer bring the functionality back?
Does restarting VW bring it back?
System restart: yes.
User logout-login: yes.
VW restart: I'll have to check. Cmd-tab fixed it too well...
A dozen manual cmd-c's and cmd-v's fixes it for a short bit.
I, personally, never use my right button in VW; a new staff member pointed it out and I've been able to reproduce it.
I found that three times in a row, a first right click did nothing, but the second one worked.
Then, it did nothing. A ctrl-leftclick shows the popup with all four edit options (cut, etc.) greyed out.
Cmd-tabbing out of -- to type this in Safari -- and back into VW restores the function.
Left click to select an object. Then right click without moving the mouse first.
Leftclick -> movethemouse -> Rightclick : your right click works.
Leftclick -> DON'Tmovethemouse -> Rightclick : right click stops is disabled for one click.
Reason: the first right click cancels the snap (cursor hint) tag. Unintended feature?
Hey, Titanium. I'm not sure if this helps, but I found a similar bug that I reported while using VWA 10.0.1 & now 10.1 with Mac OS X 10.2.3 and 10.2.4 and right clicking the mouse. It was the Caps Lock key (which I have on as the default while in VWA for text.
Might this be the same situation for you? Anyone else?
