davidwd Posted July 14, 2015 Share Posted July 14, 2015 Hi , A quick query on something ( with no doubt a simple solution) I am experiencing here Working in 2d on plans / elevations of a "ships cabin" - involving raked floor at 3deg... walls at 6 Deg etc etc .I have various repeat elements set out as symbols - working on layer plane for all. although in top /plan. On entering edit symbol with "other objects grayed out " and working in rotated plan I cannot accurately snap to any objects outside of the symbol. Lines & polylines vanish and /or leap to other positions/display angles dependant on zoom ratio. Is there a particular way I need to specify symbol creation ? or work in different process in order to display objects relative to the symbol? Thanks David Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted July 15, 2015 Vectorworks, Inc Employee Share Posted July 15, 2015 Does the same issue occur if you disable plan rotation? Quote Link to comment
davidwd Posted July 16, 2015 Author Share Posted July 16, 2015 Hi Jim , No . if Plan rotation is 0.00 everything remains visible and orientated correctly . I have tried resetting user origin to internal origin . I previously had a file where these appeared to be wildly offset and the page was leaping to offset locations on exiting groups / viewports . but this is not the case here . it is a strange display where lines / polylines display at wild angles whilst zoomed in in editing modes . regards David Quote Link to comment
