Kaare Baekgaard Posted May 1, 2015 Share Posted May 1, 2015 If I enter a scaling factor in an Extrude Along Path in VW 2015, I get an error message 9 out of 10 times. I cannot deduct what factors or parameters, that renders my objects illegal. Quote Link to comment
Benson Shaw Posted May 3, 2015 Share Posted May 3, 2015 I notice that in the EAP creation dialog, the scale field becomes inactive if path contains a corner point or if a vertex on a curvy NURBS path is converted with the reshape tool (convert mode). After EAP creation, if a corner vertex is present in the path, and the scale value is changed in OIP, the value automatically regresses to 1 when tab key is pressed to leave the Scale field. -B Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted May 4, 2015 Vectorworks, Inc Employee Share Posted May 4, 2015 Confirmed here as well. It always seems to fail with a corner vertex, but even after changing that corner to a curve it will seem to give me the 9/10 behavior. Submitting as a bug now. Quote Link to comment
