Chris Brough Posted April 17, 2015 Share Posted April 17, 2015 I've noticed when changing a custom dimension style, the already placed dimensions which use that style will not update unless you select those dimensions and re-select the same style. Is there a simple way to update all existing dimensions to the new changes without manually reselecting the style? Quote Link to comment
AlanW Posted April 18, 2015 Share Posted April 18, 2015 I use Tools / Custom Selection/ class (dimensions) then change the style to the new style. If different dim Styles you may need further selection criteria. Maybe there is a better way. HTH Quote Link to comment
