VW-PAD-Bristol-2014 Posted March 2, 2015 Share Posted March 2, 2015 I am looking to show the Hectares and Acres of a site using the space tool. So far all I can get it to show the units of the document. Is there a way I can put in a calculation to the label to allow it to show both? Many thanks Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted March 2, 2015 Vectorworks, Inc Employee Share Posted March 2, 2015 I had thought this was possible with Dual Dimensions (Controlled in the Units dialog under File > Document Settings) but that only applies to linear dims, not areas. I will check if there is a way around it, if not I will submit a request. It IS possible to include this data manually by customizing the space label symbol and adding the secondary unit, but it wouldn't be automatic then, not much more useful than just adding a text object ontop of the Space. Quote Link to comment
Tim Harland Posted March 3, 2015 Share Posted March 3, 2015 You can use the Formula field in the Additional Data tab to multiply the area by the required modifier i.e. =#Gross Area#*.0.40468564 to show hectares if your units are acres or the inverse. Quote Link to comment
VW-PAD-Bristol-2014 Posted March 5, 2015 Author Share Posted March 5, 2015 Thank you Tim, That is a great help. Jim would it be possible to add this to the wish list as I think it would a good feature if it was a simple drop down. Many Thanks Quote Link to comment
