Kaare Baekgaard Posted December 2, 2014 Share Posted December 2, 2014 (edited) I may have missed a setting here, but here is the problem: Every new viewport I make comes with transparent background as a default. It looks OK on a monitor, but it prints very poorly with strange grey edges. I wish new viewports always had solid fill as a default. Edited December 2, 2014 by Kaare Baekgaard Quote Link to comment
0 Vectorworks, Inc Employee PVA - Admin Posted December 2, 2014 Vectorworks, Inc Employee Share Posted December 2, 2014 Could you post an image of the print results you are getting? A Fill of None shouldn't create an odd effect as you describe. Still a perfectly good wishlist item though, it can be controlled via class attributes but an option within the Create Viewport dialog that could be saved by default would make sense as well, submitting it now. Quote Link to comment
0 Kaare Baekgaard Posted December 2, 2014 Author Share Posted December 2, 2014 I would be surprised, if not every VW user has had the same experience. I have seen the effect on every printer, I have used, but it is especielly visible on laserprinters. The problem is, that pure white becomes transparent in the viewport, but any amount of colour or gray will make the pixels none-transparent. The edge between transparent and non-transparent pixels will print slightly tinted – resulting in an odd effect. I dont think my camera will catch this, but I am sure, you will see the same effect in images with a lot of white-ish objects. Quote Link to comment
0 Vectorworks, Inc Employee PVA - Admin Posted December 2, 2014 Vectorworks, Inc Employee Share Posted December 2, 2014 Would you mind posting an example VWX where you see that happening, please? I am unable to replicate it on any of the printers here as you describe. Quote Link to comment
0 Kaare Baekgaard Posted December 5, 2014 Author Share Posted December 5, 2014 Sorry Jim – I forgot crucial information: I make pdf's from my sheet layers... Then I compress the pdf's, so I can mail them to the customer... THEN the problem arises – if I forgot to give renderings a solid background. Here is a white object on a solid backgrund: Here is the same object without background fill: Here is a pdf with two pages - the second page has no solid fill behind the rendering: https://drive.google.com/file/d/0BxL3Oyph55RRcDhRcFZ6UXdyMFk/view?usp=sharing I am sorry for the confusion Quote Link to comment
0 Vectorworks, Inc Employee PVA - Admin Posted December 5, 2014 Vectorworks, Inc Employee Share Posted December 5, 2014 Ahh gotcha, compression can indeed do that. Depending on the type, it will attempt to average pixels together. Its most likely stumbling when it comes to the transparent components. I'll mention this in the wish. Quote Link to comment
Kaare Baekgaard
Edited by Kaare BaekgaardLink to comment
5 answers to this question
