Macluskie Posted November 28, 2014 Share Posted November 28, 2014 Hi I have a complex 3D object made from several 3D solids I want to subtract a simple 3D rectangle from the overall object BUT retain the individual pieces I know I can do this by subtracting each individual component but this seems like multiple identical steps I don't think there is an option to Subtract Solids from multiple shapes in one go but does anyone have any suggestions to a workaround? Cheers Quote Link to comment
bcd Posted November 28, 2014 Share Posted November 28, 2014 A couple of ways: Select your primary 3d solids and Model>Add Solids. Then select this new solid addition and your subtracting solid and Model>Subtract Solids. The original solids remain editable via Modify>Edit Solid + Modify>Edit Solid. or: Select your primary 3d solids Modify Create Symbol You can then subtract solids from the symbol and subsequently edit the primaries by editing the 3d symbol. Quote Link to comment
Macluskie Posted December 1, 2014 Author Share Posted December 1, 2014 Thanks for that Looks like Stitch and Trim Surfaces works too :-) Quote Link to comment
bcd Posted December 1, 2014 Share Posted December 1, 2014 yes, as long as you don't need the object history. Quote Link to comment
Chris Brough Posted October 28, 2015 Share Posted October 28, 2015 Good tips @bcd. However, i would like to batch subtract one object (say a dowel) from multiple plywood/solid wood parts, while keeping those individual parts separate. Is there a way to accomplish this without repeating the subtract command for each part? If not i'd like to suggest this be added to the wish-list section. 1 Quote Link to comment
bcd Posted October 29, 2015 Share Posted October 29, 2015 The only way is to convert your assemblage into a Symbol and Solid Subtract from that. A fair wish would be to Solid Subtract from a Group. Otherwise you can perform repeated SSs and check the Retain Subtracting Objects box so at least you don't need to duplicate the dowel. Quote Link to comment
