Tom Klaber Posted October 3, 2014 Share Posted October 3, 2014 When I use the publish command to do a set print, and then select all the items to change the print settings, even though it looks like all the items are selected, the changes to the print settings will only affect the first item on the list. I am not sure if this is a bug or just the way it is supposed to work, but it would be great if I was able to change setting and parameters on multiple items once while inside the publish command dialog. Thanks! Tom Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted October 3, 2014 Vectorworks, Inc Employee Share Posted October 3, 2014 That is not the intended behavior, it seems to be allowing separate settings for PDF but in Print its defaulting back to the originals once you select another item. Submitting as an issue now. Quote Link to comment
