Katerina Posted January 9, 2003 Share Posted January 9, 2003 In VW8 there was a plugin to open early version Minicad dwgs. Is there anything for VW10? Quote Link to comment
Guest Posted January 9, 2003 Share Posted January 9, 2003 VW 10 can convert MiniCad 7, 8 and 9 files to VW 10. VW 9 can convert MC 6, 7 and 8. If you are trying to convert a file prior to Minicad 7, you will need to contact sales to have one of the in between versions sent to you. You can then convert the files to taht version, thus allowing you to convert them to VW 10. If you go to File > Open you should be able to select the file and open it. A conversion dialog box will appear. There is also a batch convert command which can convert an entire folder of files at one time to VW 10. Quote Link to comment
