zoomer Posted August 19, 2014 Share Posted August 19, 2014 I don't understand why there are two entries in the import dialog. The "import single DWG" has the common parameters for DWG import. The "import DWG" has additional parameters but you can reach the other main parameters from "import single" but not vice versa. f.e. if you accidentally set the "Architectural Elements" to 2D, this will influence the "import single" Import but you can't change that setting from there, and you won't be able to get 3D files in "import single" until you changed the settings there. I think there should be only 1 dialog with all settings ! Same for Export, if I am not wrong there are still some exports where it depends on your current View Window setting being 2D or 3D, wether you will export 2D or 3D. I think these options belong to the export settings window only. Quote Link to comment
zoomer
Same for Export,
2D or 3D.
0 answers to this question
