surreal1973 Posted August 11, 2014 Share Posted August 11, 2014 I'm trying to send a file to a friend so he can print it on his 3d printer but the .DWG and .DXF format aren't working. They come up as wireframe even when I render them. Any suggestions on a format that the 3D printer will read as a solid object? Thanks Quote Link to comment
Kevin McAllister Posted August 11, 2014 Share Posted August 11, 2014 How an object is rendered shouldn't affect its ability to be 3d printed. Do you know what software your friend is using to open and print the file? Normally files for 3d printing are exported as STL files ( File>Export>Export Stereo Lithography ) from VW. An STL file is made up of polygons. The file you're exporting needs to contain closed 3d objects (ie. solids or closed meshes). STL files are then processed into a file the 3d printer can understand (varies by 3d printer). These files are usually created by software included with the printer. I 3d print VW files all the time so it is possible. If you continue to have trouble you could post an example file. Also, please add a signature to your profile (Under My Stuff at the top of this page) that details your system and version of VW. That could help us solve your issue. Kevin Quote Link to comment
surreal1973 Posted August 27, 2014 Author Share Posted August 27, 2014 I exported as an STL file and it worked fine. Thanks. Quote Link to comment
Guest Wes Gardner Posted August 27, 2014 Share Posted August 27, 2014 Hi All, Just FYI,there is a FREE download of a program called meshlab that can help you view your STL files... Wes Quote Link to comment
